View Full Version : Engine, Drivetrain & Forced-Induction
Pages : 1 2 3 4 5 [6] 7 8 9 10
  1. HELP! someone, blackbetty help!
  2. Lurching in first gear??
  3. Limp Mode
  4. Mobil 1 Extended Performance Synthetic Oil
  5. performance chips
  6. Transmission whine on 6MT
  7. Exhaust Question
  8. Eneos or Royal Purple?
  9. Why, oh why, did the 3.7L not increase in torque?
  10. g37s clutch has no feel?
  11. Turbo Charge
  12. What is your engine RPM the first 5-10 seconds you start the car ?
  13. Shift Lag / Transmission Problems - Rant Warning (Help Requested)
  14. UpRev engine management
  15. Clutch got Stiff all of a sudden...
  16. Forged Performance: Another Time Attack Victory and a class record at VIR!
  17. g35 short throws??
  18. clicking from engine at idle?
  19. Buzzing after spirited driving
  20. question about DS
  21. Stillen cold air intake
  22. SES light code P0605
  23. Trackday Datalog - Hello Limpmode
  24. Automatic
  25. $25.00 Pulstar Pulse Plug. Its Not A Spark Plug
  26. ECU reflashed at technosquare
  27. What is the Best Oil for the G37S MT
  28. betty's grounding kit
  29. OBD wireless app for iPhone/iPod touch
  30. Cobb test mule
  31. Atessa - e AWD system.
  32. 1st oil change free? not for me
  33. help- problem with new car
  34. VVEL and TSB
  35. Info on 7AT
  36. question about downshifting with paddles
  37. Should I feel depressed with my 5AT 08 G37S
  38. trouble shifting from 2-3gear
  39. HOw to use the auto shifter in manual mode...
  40. Forged Performance: VQ37 500whp+..another first!
  41. after 1200 miles then what??
  42. Tranny problems?
  43. Should I change my oil?
  44. gears are too close?
  45. big problem with car any ideas what it could be??
  46. Synthetic Oil (ester base) stock From Factroy
  47. 7 Speed AT
  48. Low oil????
  49. 7at
  50. Engine trouble -- help diagnose?
  51. Problem, knocking sounds from the rear when shifting
  52. Mobil 1 instead of Ester base Oil?
  53. Is this what they call axle clicking?!?
  54. over revved engine
  55. feel of G37S clutch
  56. Transmission: Auto with DS vs Paddles vs 6MT
  57. Need Power
  58. 6th gear grind and noise issue and updated iPod connector(iphone3G)
  59. Cams??
  60. Acceleration change
  61. knocking/missing noise from engine when idle
  62. Oil Change?
  63. Any one know any thing about the Infiniti Ester motor oil?
  64. Hard Shift Into 1st or 2nd Gear
  65. PDF on VVEL technology
  66. Does the LSD need to be warmed up before working properly?
  67. launching the G
  68. please help decide!!!!!!!!
  69. My Dyno numbers for all my mods....
  70. Question: Reflash and Crank Pulley
  71. Oil catch can
  72. Where can you get your ECU flashed
  73. Interesting clutch issue. (CLUTCH DELAY VALVE?)
  74. User Experiences? > Innovate OpenTune TM OBD-II / CAN Interface
  75. Engine Problem at 3kRPM
  76. Infiniti F'd my Oil Change up!!! What now???
  77. i dont think my vdc shuts off
  78. Infiniti Servicing:
  79. Any way to add paddle shifters to a base modle G37 w/o harness inputs on the column?
  80. 15,000miles/12 month service needed?
  81. Oil Consumption on G37
  82. Engine Humming?
  83. Anyone had or heard of this one?
  84. loud rumbling on cold start
  85. Shaking Tranny
  86. Power Combo - Good Combo?
  87. TT G37S 6 speed OR TT G37X coupe (09 AWD)
  88. JWT Clutch and Flywheel Combo....Finally!!
  89. Forged Performance Cleans up at Redline Time Attack at Summit Point
  90. For 6MT owners - Skipping 5th...
  91. Got a check engine light too :-(
  92. for those who change their own oil.....
  93. Stripped bolt on Engine block
  94. check engine light....WTF???
  95. [V]HR Stillen Headers
  96. About to do an Oil Change need info first!
  97. Dealer Install
  98. G37 clutch the same as 350z/G35?
  99. Portable accelerometer-based dynometer better then G-Tech?
  100. Paddle Shifts slow?
