MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Go Back   MyG37 > G-Spot > G37 Sedan
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 11-14-2009, 06:25 PM   #1
blitzebill
2009 Infiniti G37
Trader Score: (0)
problems with the Goodyear Eagle RSA tires?
i just bought an 09 G37x sedan and the OE ties are the Goodyears.
I've been reading some reviews at tirerack.com and other places that go so far as to say DO NOT USE THESE TIRES.
i'm concerned about this of course.
I've been reading about the Michelin Primacy MXV 4 tires. a bit pricey but supposedly outstanding tire.
any recommendations?
thanks!
blitzebill is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-14-2009, 07:17 PM   #2
Mike
Trader Score: (0)
honestly, tirerack reviews are all across the spectrum. Generally, the higher performance tire you get, the pickier the consumer, and reviews reflect the pickier consumer.
Take them with a grain of salt. if you're driving in snow, I'd recommend some snow tires. Otherwise, see if YOU are happy with them.
Mike is online now   Reply With Quote
Old 11-15-2009, 12:39 AM   #3
SkyMG37x
SkyMG37x's Avatar
Trader Score: (0)
You should delete one of your posts since you have this posted twice.
__________________
John - 2009 G37x Sedan Blue Slate/Stone with Premium/Nav - Ventureshield
SkyMG37x is offline   Reply With Quote
Old 11-15-2009, 12:57 AM   #4
JIM56
Trader Score: (0)
The Goodyear RS-A's are fine. The tire provides good dry traction, good cornering traction, handles relatively quickly, has low tread noise, is quiet on rough roads, and absorbs bumps well. I've had no problem with wet traction, but I had a set several years ago that hydroplaned one time, so I'm always a little cautious. The rubber seems soft, so I don't expect much mileage. Winter traction may be mediocre.
Every tire is a compromise, so it is somewhat of an individual choice. (But a new tire almost always seems better than a worn out tire)
For the P225 55 R17, I will probably look at Bridgestone Serenity which I have on another car (little more treadnoise, much better treadwear, excellent on wet roads, but slick on snow) or maybe look into the Michelin Primacy or Michelin Pilot A/S. There seems to be some limitations on what is available in this size.
JIM56 is offline   Reply With Quote
Old 11-15-2009, 10:22 AM   #5
Hi Alt G
Trader Score: (0)
They also seem fine to me. Granted I've only driven 1000 miles on them, but they work well in the snow (much better than the reviews at TR would have one believe) and the ride comfort and noise aren't bad at all. I called TR and asked if they thought I should change to a different all season tire due to the reviews on their site and, amazingly, the TR rep said he thought I would be fine given the X part of the G37X. Now that says something, a salesman who did not try to sell me something he did not think I needed. Hat tip to Tire Rack. I vote with Mike, give them a try.
p.s. Any tire with a 260 UTQG rating is not going to last a bunch of miles.
Hi Alt G is offline   Reply With Quote
Old 11-15-2009, 10:40 AM   #6
blitzebill
2009 Infiniti G37
Trader Score: (0)
thanks for all the quick replies and suggestions!
Old 11-15-2009, 02:00 PM   #7
jane
Trader Score: (0)
I wouldn't use over priced/over rated goodyears my self.
jane is offline   Reply With Quote
Old 11-15-2009, 02:55 PM   #8
classy37
2009 Infiniti G37
Trader Score: (0)
If you got the G with RSAs, plan to replace them. If you are even considering buying them as a replacement, stay away. These tires are downright dangerous on any degree of wet pavement IMHO. Dry traction is subpar, but predictable. I can't wait to get them off, just trying to squeeze out a few more weeks before snow starts falling.
I slide on the tires on minimally wet pavement and have have had several near wipeouts in 4 months of ownership.
Seriously, stay away.
classy37 is offline   Reply With Quote
Old 11-15-2009, 04:31 PM   #9
Mike
Trader Score: (0)
Sounds like you need to slow down. Remember, surfaces are most slippery after a fresh rain with minimal moisture being the most dangerous...
Old 11-15-2009, 05:01 PM   #10
classy37
2009 Infiniti G37
Trader Score: (0)
Quote:
Sounds like you don't know how I drive. This is not my first car or set of tires. Are you aware that there are A/S tires that just do not do well in wet, despite being A/S? The RSAs are one of such tires.
Old 11-15-2009, 05:04 PM   #11
JIM56
Trader Score: (0)
Like I mentioned, I had some hydroplaning about 10 years ago on some RS-A tires -- basically travelling about 70 in rain on an interstate where the steering just failed to respond. I think the tires were well worn in. So, be cautious.
I've had no issue with the current OEM RS-A tires but have not pushed them that hard on wet pavement. Were these issues with traction, braking, or cornering? Did the VDA and AWD keep the car controllable? Was this just wetted pavement where oily film can really make it slick regardless of tires? Just wondering under what conditions might be an issue.
If the tires were that dangerous, I think I would swap them immediately.
Old 11-15-2009, 06:05 PM   #12
ozzypriest
Trader Score: (0)
RSAs are pretty junky. There are 2941 survey results on the RSA and they receive, on average in most categories, absolutely atrocious ratings. I had them on my G8, I am cursed with them now, and I agree with the professional reviews as well as the consumer reviews on tirerack - they are JUNK!!! There are so many other, better all-weather performance tires out there (apparently at least 15).
From Tirerack RSA page:
Would You Buy This Tire Again?
Most said: "Probably Not" (Average of 3.6 out of 10)
How Did This Tire Rank In Its Category?
17 out of 22 tires (Score of 5.5 vs best tire in category score of 8.4)
Goodyear Eagle RS-A
__________________
G37 Sedan Journey Platinum Graphite
ozzypriest is offline   Reply With Quote
Old 11-15-2009, 10:00 PM   #13
Mike
Trader Score: (0)
Again, I don't know why you go by tirerack surveys
Here's an example
Dunlop Direzza Sport Z1 Star Spec
I think we can agree that those tires are next to worthless in the rain, but look how high the wet surface rating is.
Bridgestone Blizzak LM-25
I think we can also agree that snow tires do NOT grip anywhere near the level of an A/S or Summer tire, but check out those dry ratings.
Old 11-15-2009, 10:16 PM   #14
classy37
2009 Infiniti G37
Trader Score: (0)
Here's an example
I don't have personal experience with either of those tires, but take a look at the sample sizes of the respective tires' survey results.
Goodyear RSA = 2,941 submissions
Dunlop Direzza = 246 submissions
Brigestone Blizzak = 353 submissions
Based on this, I have much more confidence in trusting the validity of the RSAs' ratings than I do the Direzzas' or Blizzaks'.
How do you throw away the experiences of 2,941 survey results? Do you think tire rack reviewers are so different from the posters contributing to this forum?
Old 11-15-2009, 10:21 PM   #15
jane
Trader Score: (0)
Here's an example
I'll use TR ratings but not what the users say that don't know how to drive anyway.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
