| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#16 | |
2009 Infiniti G37 |
Quote:
![]() basically exactly how you described...slowly accelerates then when you least expect it, the SOB takes off... not very safe or flattering also in D, if I mash the pedal it takes a good second or two to kick in. Hoping the grounding kit eliminates some of this.
__________________
09 BS G37xCoupe |
#17 |
I think it's the problem with Drive-by-Wire technology. Does our G have DBW?
I had a Lexus RX330 with the same problem, but I didn't care because it was a Lexus. I understand the G is supposed to be a performance car. So this should not happen
#18 |
Yes, the G is drive by wire as most cars are now.
However DBW shouldn't have this issue. |
#19 | |
Quote:
As for the grounding kit discussion, did not intend (or want) that to takeover the thread rather just trying to find out if I was the only one with this problem. That doesn't sound like the case though although apparently not as widespread as the flare issue.
__________________
'09 Blue Slate G37S Sedan 7AT Nav/Premium |
#20 | |
Quote:
Yes, DBW but everything is linked (electronically) to everything else thus who can say it's DBW, TCM and ECM or anything else without looking at it? What scares me is that unless it's throwing codes, which it is not, I'm sure the dealer will tell me "unable to replicate" and I do not have time to take it to the dealer 10 times before they can replicate it. By then I'll be so pissed about the car I'll hate it and I do not want that to happen. Did that with one of the first 6-speed TL's to roll off the line in 2004....made Acura buy it back and then I switched to Infiniti. I love my Infiniti(s) so I guess I'll just have to put up with it until someone else gets pissed and figures it out.
__________________
#21 |
G35 Rhino,
I just had mine flashed today at Charlotte Infiniti. I've had my car since Feb and I've been pretty impressed with the service dept there. I'll let you know how the shifting goes. The drive home was fine. I was thinking about the mileage being affected so I'll keep an eye on it using manual calculation method. I never have trusted the on-board computer. Before the flash, I was getting 25-26 MPG average with 80 hwy/20 city. My best was all hwy up to VA which I was able to get 30 MPG. I'm hoping it's not affected by the flash as I was enjoying what I was getting! |
#22 |
2009 Infiniti G37 |
I haven't experienced much throttle lag bug the car was chugging on a very humid day. My mpgs did not get worse either. Waiting to see if this chugging happens on another warm humid day but the weather has been very un-summer like.
__________________
'09 G37xS 4Dr Liquid Platinum, Prem., Navi., and some wierd cabbie air freshener... |
#23 | |
Quote:
IMO Infiniti of Charlotte's customer service has gone down since 2005 when I lease my '05 G35. I believe they have changed ownership (now part of Sonic) and that may have changed their philosophy somewhat.
__________________
#24 |
OK so this happened again today and I'm starting to be able to narrow it down a bit. It seems that I am having issues when I am rolling/coasting and then floor it. It has happened in D at 5 mph or so when I gunned it (requiriing it to downshift) and I noticed it big time today when driving at ~40-ish mph then gunned it to force a downshift. I tried it several times in a row and when the car was rolling/coasting downhill (less of a load thus throttle partially closed) at ~40 mph it lagged big-time however doing same on an uphill grade (having to constantly feed fuel) the car did fine. Any ideas?
__________________
#25 |
My G8 Gt suffered from this from time-to-time, it was drive-by-wire. It was transmission protection programmed into the TCU. A tune similar to the Cobb accessport fixed this issue. What I don't understand is why is there not a trans tune for the G37? Is the TCU not accessible for re-programming? Can the tuners not figure this out? Is there something about the TCU that makes it difficult to tune or access? IMO, the 7AT has a total granny tranny in the sense that there is a LOT of torque management & lack of good shift pressure, and PURPOSEFUL throttle lag, probably there in order to avoid drivetrain lash, etc. That throttle lag is also **there on purpose**. It's the Infiniti engineering team's response to ensure drivability and drivetrain component sustainability. They, like most manufacturers, are being extra careful.
That being said, I removed most of the torque management from my GT, adjusted the shift pressure and shift points, and I was a happy m-fer. It was a performance tune, and too rough for a lot of people, but just adjusting the transmission made the car about .4-.6 secs faster 0-60, and about .3 secs faster in the 1/8 and 1/4 mile. So where's the transmission tune for the G37 AT? |
#26 | |
Quote:
I SERIOUSLY DOUBT the issue I am having is a conscious thing on the part of Infiniti. There are too many enthusiasts here to not be complaining about this problem so I do not believe it is a characteristic of the car in general. I think a small subset of the population is having issues not widespread.
__________________
#27 |
As ozzypriest mentioned i think the throttle lag is there on purpose and i also believe that the reason why its there is because its a safety feature. Reason being is that in case you have an emergency situation (panic stop) and accidentally slam on the throttle instead of the brakes, you would not want to accelerate faster into the accident. That delay gives you enough time to notice that you are not stopping as you should be and allow you to readjust yourself to apply the brakes.
This is why if you have a constant feed of fuel you would not experience any throttle lag (not a panic situation) however if you were to close the throttle and then gun it (can be interpreted as a panic situation) you would experience some form of delay.
__________________
09 7AT G37S Sedan: BO / 35% Tint / LED swap / BBGK V2 |
#28 | |
Quote:
__________________
G37x Sedan Prem/Nav Packages |
#29 | |
Quote:
__________________
#30 |
I went to the BMW performance driving school and an instructor described some throttle delay (not exact words) which BMW incorporates as a safety feature in case of a panic situation.
I i'm not saying that Infiniti incorporates the exact same logic however i can see where it would come in handy in a panic situation. You should try gradually depressing the throttle as opposed to stomping on it and see if it behaves differently.
__________________
| Thread Tools | |
| Display Modes | |
