| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#1 |
09 G37 w/Nav --- 3000 Miles
I had scheduled an appointment today at Infiniti service department due to the same problems a lot of people on here seem to be experiencing. Seemed like the RPM was flaring and shifting awkward as well as that popping feel when it's searching for the gear. I happened to see the TSB posted in one of the threads here so took that with me. They had not heard of it, so I showed it to the service manager, he was very interested in it. Anyways a couple of hours later I get a call that they are going to have to keep my vehicle over night. They said whenever they took the car to the back, the engine service light was on, and now they have to replace the ECU, Engine Computer. (The engine light had not been on any time prior) They also said that the TSB did not pertain to my vehicle... Just wondering what peoples thoughts are on this? I'm worried as I'm sure everyone is that this is going to be an on going problem. I'm supposed to have the car back tomorrow, so we'll see. Last edited by Zydan; 07-02-2009 at 10:49 PM. Reason: Engine Computer - Not Engine Control --- Sorry |
| Sponsored Links | ||
#2 |
The MIL lamp would have been a separate issue than you reported. I would suspect that the ECU replacement was due to that.
As for the TSB, I assume you're referring to the one for the downshift smoothness, and it should definitely apply to your car. Your description of your issue sounds different so not sure if that's what you explained to them but nonetheless the TSB is applicable - they may not have the latest info though. Also, it requires reprogramming of the TCM (Transmission Control Module), not the ECU, so the ECU issue seems separate.
__________________
John - 2009 G37x Sedan Blue Slate/Stone with Premium/Nav - Ventureshield Last edited by SkyMG37x; 07-02-2009 at 08:43 PM. |
#3 |
out of curiousity when u floor it and let it shift does it make a squealing noise between gears??
#4 | |
2009 Infiniti G37 |
Quote:
__________________
'09 G37xS 4Dr Liquid Platinum, Prem., Navi., and some wierd cabbie air freshener... |
#5 |
its a 46 speed autotragic... seriously its an 09 37 what trans do you think is going to be in it?
__________________
2009 G37S Sedan 6MT - Platinum Graphite/Stone - Premium/Nav/Tech DOB - 12/2/08 Purchased 1/9/09 |
#6 | |||
First of all it was supposed to be Engine Computer, not Engine Control~ Sorry about that.
Quote:
Quote:
Quote:
Here's the link another member posted of a picture of the TSB. http://www.imagedump.com/index.cgi?pick=get&tp=550499 The service guy stated, and I quote, "We had a technician check out the TSB and there was no update to your TCM, transmission control Module, it either did not need it or yours had the most update software in it." Well I know I don't have the most recent update since I purchased car in early May and the TSB didn't come out till June 26th. |
#7 |
I just took my car in today at my local Infiniti dealership to handle the rough downshift between 4th and 3rd gear. Took the same information provided at: http://www.imagedump.com/index.cgi?pick=get&tp=550499 and advised that they have not heard of this, however the TSB was able to help. Received a call 3 hours later and on my receipt its states the following:
Performed Bulletin 09-032 Reprogrammed TCM Replace old part #31039-1XJ4A new part #31039-3RX0C The ECU issue is totally seperate from the TSB for the TCM. I drove my car back to work and the rough downshift is no longer there. Great info all! |
#8 | |
Quote:
__________________
John - 2009 G37x Sedan Blue Slate/Stone with Premium/Nav - Ventureshield Last edited by SkyMG37x; 07-03-2009 at 12:23 AM. |
#9 |
Your right, I have an 09 G37 w/ Prem and Navi. No "sport" option and I was still having the same issue with the rough downshift. SkyMG37x is correct, TSB is very misleading and does not necessarily mean that you have to have the "sport" option as this was the case for me.
#10 | |
Quote:
#11 |
First, I would ask to see if they have any information to why the ECU now needs to be replaced?
Second, while your G37 is already at the dealership then I would link it back to the TSB update for the TCM and while it's there, just get it done. The TSB should give them all the needed information on how to handle this issue. My dealership here had no problem in correcting this. I just hope that you don't spend too much time dealing with them, and just be specific on your approach and I would push for more information due to your issue. Hope everything goes well for you |
#12 |
It won't hurt to try, not sure if part number is specific or generally the same with all 7AT.
#13 |
Ask your service advisor to call their Infiniti technical support line to verify that the TSB does in fact apply. If they still claim that it doesn't, you can also call Infiniti customer service and ask them for assistance.
__________________
John - 2009 G37x Sedan Blue Slate/Stone with Premium/Nav - Ventureshield |
#14 | |
Quote:
I want to call them and ask them how they find out if a car needs the update. My service guy said they hook the car up to something that is linked nationally, and run the check and my car came up with no update needed. |
| Thread Tools | |
| Display Modes | |
