| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#16 |
MYG37.COM Sponsor
I've been thinking about this more and I'm pretty sure it won't be a problem with your cats. However, I would recommend pulling out your air/fuel sensor, the one in front of the cat, and swapping sides...This will tell you if it is a problem with the sensor or not.
Also, take a close look around all of your connections and make sure the intake is still sealed. If you have a leak around the intake it can cause this code.
__________________
For fastest service please email me at kmillen@stillen.com. PM's can sometimes take me a day or two to answer. |
#17 |
Stillen G3, Test Pipes & FI Catback and still not lean enough to trigger CEL
Something is definitely wrong
__________________
'08 AG G37S 5AT | Fully Loaded | Tint | Clear Bra | FI CF Catback | PC Rims | BB's V2 GK | Eibach Pro Kit | Painted Grille | 4x20mm H&R Spacers | Stillen 3rd Gen Intakes | FI Non-Res Test Pipes | Customized Fox Resonators | FR:245/40 RR:275/35 | UR Crank Pulley | PIAA Fogs | Debadged & Valenced | Painted Headlights Before you post: - Check out this lovely feature! - Read our Guidelines - Read the forum rules - Learn how to post Getting lost in this place? | Want to become premier? | Want to mod but don't know where to start? | Need specs of OEM wheels? | Got G? Check In! | We know what a G looks like, what do you look like? | Classic post? Post it up |
#18 |
2008 Infiniti G37 |
i will swap the sensor and see and will report it here
#19 |
Be VERY careful trying to take the sensors out because they can be a huge pain in the @$$. Plenty of people have stripped the threading on them and had to replace both of them at $170 a pop from the stealership. If you're not familiar, I would have a trustworthy mechanic do it.
__________________
'08 Infiniti G37s 35% Tint - Stillen G3 Intakes, Fast Intentions Res TPs, Catback, Eibach Pro Kit, Kics 15MM Wheel Spacers, JWT Clutch and Flywheel, Innovative Motorsports Wideband, N2MB 2-Step... 335whp-269ft-lbs Cobb A/P Tuned! |
#20 |
2008 Infiniti G37 |
okay this is some days after.
I went to local mechanic and they reset my ECU. i've been driving since now but when it's very cold outside, engine check light is on. i am not sure if cold weather causes the main problem but it seems to be because of that. and it went away when it got warmer yesterday. any problem with any intake reported yet? |
#21 |
Ohio G Club VP
I just got a dyno done last Wednesday and my A/F was around 12-13 and I was told that was good. I have the Gen3 and MXP.
__________________
![]() MHT Tanabe MXP TS Lip Midnight Grill BB Kit Gt Spec Status Elite Stillen Gen 3 Hideaway Plate Black Roof Hawk pads UpRev More to come.... |
#22 |
2008 Infiniti G37 |
any good dyno place in norther NJ? im in bergen county
| Thread Tools | |
| Display Modes | |
