| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#1 |
Dealer set tire pressure on 28 psi
Why would they do that?? I decided to check my press this weekend since it's been colder out and it's 28. I only had the dealer mess with my tp so far. Shouldn't it be 35 like the doorsills suggest, and why hasnt my TPMS light gone off
![]() Oh, I got the stock sport 19's by the way
__________________
'08 IP G37S|Coupe|Graph|Prem|Sport|LEDs|18%tint|Injen CAI|Eibach ProKit|FI HFC's |
| Sponsored Links | ||
#2 |
MYG37.COM Sponsor
2008 Infiniti G37 |
It might be lower cause of the cold. But yeah they should def be like 34-36
__________________
ON VACATION ![]() G37NYC~180°~Iforged~Mastergrade~Seibon~Injen~Berk~ HKS~JIC~Hotchkis~GTSpec~Stoptech~ ![]() |
#3 |
El mero mero!
TPMS on our cars is a joke. I think it has to be at least 8 PSI low before it indicates. And it doesn't tell you which tire is low or how low it is. Useless.
What was your dealership doing adjusting your tire pressures?
__________________
Get your custom grounding kits at |
#4 | |
Yeah, your dealer messed up. Alway keep them inflated to spec as the sticker notes.
Quote:
So for those of you in colder temp areas, yes you should always check and inflate your tires when "cold", but what that means is not immediately after driving because because driving generates friction and heat that increases the pressure inside the tires. I know you know this BB, but just making it clear for some folks that may not.
__________________
09 G37S Coupe 6MT -- Moonlight White | Graphite | Premium | Nav | Tech | 4WAS | ClearBra | 35% FormulaOne Tint | KW Variant 3 | SPL Pro Rear Camber Kit | Vossen VF051 Custom | RIP -- 08 G37S Coupe 5AT 11.2007 - 02.2009 Maintained with products exclusively from Detailed Image |
#5 |
Yeah, supposedly they "check it" during service, at least that's what the service order said. I thought it was kinda too low so I added air and now they're all at 35
__________________
#6 |
2008 Infiniti G37 |
It says 35psi for you guys? My door says 32psi. My TPMS came on when they all dropped to 29psi when it got cold in VA after I moved up there. Big temp difference between AL and VA.
__________________
'08 PG G37S, Premium, FI Cat-back, Fujita SRI, Stillen Spoiler, 8000K D2S |
#7 |
depends on size .... stock 18" is 33psi and 19" is 35psi. When I bought my used G the dealer had them at 42-46 ...my guess is to prevent flat spots while sitting on the lot.
__________________
2008 Journey,Premium,Blue Slate | Illuminated Sills | LED's-Trunk,Door,Map & License |
#8 |
2009 Infiniti G37 |
I have factory 19s (sport model) and did a little experimenting when I got my car. TPMS alerts @ less than 30 PSI. Living in the NY tri-state area I keep my tires at 39 PSI in order to provide extra protection from harsh potholes & roadway irregularities. Above 40 PSI the ride gets a bit harsh and below 34 PSI feels a little sloppy.
__________________
'09 G37S Conv 6MT - Platinum/Graphite | Prem | Nav | Tech |
| Thread Tools | |
| Display Modes | |
