| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#16 |
yea.. ^ honestly hes a respected guy on the forums so dont be so quick to bash people. i used to love being on here and now its played out cause of all the trash talk
__________________
crashed...
#17 |
probably just a more restrictive exhaust.
#18 |
#19 |
come on people newton's second law: F=ma lol
__________________
'08 AG G37S 5AT | Fully Loaded | Tint | Clear Bra | FI CF Catback | PC Rims | BB's V2 GK | Eibach Pro Kit | Painted Grille | 4x20mm H&R Spacers | Stillen 3rd Gen Intakes | FI Non-Res Test Pipes | Customized Fox Resonators | FR:245/40 RR:275/35 | UR Crank Pulley | PIAA Fogs | Debadged & Valenced | Painted Headlights Before you post: - Check out this lovely feature! - Read our Guidelines - Read the forum rules - Learn how to post Getting lost in this place? | Want to become premier? | Want to mod but don't know where to start? | Need specs of OEM wheels? | Got G? Check In! | We know what a G looks like, what do you look like? | Classic post? Post it up |
#20 |
#21 |
#22 |
Just a bit of FYI to the OP... there will ALWAYS be a different HP/Tq (in terms WHP/WTq, be it corrected or not) rating between automatic and manual transmissions, even on cars with the exact same engine. There is more parasitic power loss when transmitted through an ATX then an MT, each time and every time. Same goes for drive wheels. A RWD car will have a greater engine to wheel power loss then a FWD car, and an AWD car will have more loss then either of the two.
Of course, most manufacturers will only state BHP, which is rated at the flywheel and not the drive wheels, so that figure would remain the same no matter what transmission or drive wheel configuration is used.
__________________
'08 G37 Coupe (Obsidian Black) - stock : '91 Toyota MR2 - 296RWHP - 12.8@106MPH |
#23 | |
Moderator of Pwnage
Quote:
__________________
'08 BO/Graph -G37S Journey/Sport/Premium/Nav/Spoiler/Exhaust Depot Y-PIPE/ BBGK/ K&N/ Mich Pilot Sport AS+ 245F..275R/Tanabe NF210/ Stillen Cross Drilled/ Metal Matrix Pads Former Car '03.5 G35 Coupe Premium/ Sport/ MD Spacer |
#24 | |
Quote:
This is a moot point
#25 | |
Not really, given that I was referring to this quote from the OP...
Quote:
__________________
'08 G37 Coupe (Obsidian Black) - stock : '91 Toyota MR2 - 296RWHP - 12.8@106MPH Last edited by boostard; 05-28-2009 at 04:02 AM. |
#26 | |
Quote:
As long as the SAME dyno is used and the calibration is unchanged, correction will factor for atmospheric pressure, temperature, and humidity. Altitude is not a concern. Given your statement, no two dyno pulls can ever be compared cuz conditions change in real time, and will never be identical twice. Anyways, the engine DOES output different power on different models. |
#27 | |
Quote:
BTW, who said anything to the contrary about different model cars not making the same power? Not I. I only stated about the differences between transmission types. ...and when you are trying to compare the difference of ~5-10 HP, then YES, it makes it very hard to compare dynos which are done at the same place on the same day let alone at on different days and at different places (and on different types of dynos as the case may be). In any case, Id like to see these dyno charts which were mentioned showing "2 to 3 HP" differences between MT and ATX models. I would also be interested to see when, or better yet WHERE they were performed and on which type of machine. Without those last two variables accounted for, your "proof" isn't worth much.
__________________
'08 G37 Coupe (Obsidian Black) - stock : '91 Toyota MR2 - 296RWHP - 12.8@106MPH Last edited by boostard; 05-29-2009 at 12:12 AM. |
#28 | |
Moderator of Pwnage
Quote:
__________________
#29 | |
Moderator of Pwnage
Quote:
![]() . . . edit.. so I lied.. Here is the link to the G35 dynos. Particularly look at the 5AT HR dyno (second from bottom) and the 6MT HR dyno (at the bottom). They are within 2 to 5 HP of eachother http://g35driver.com/forums/1684290-post1.html There are more out there with the G37 dyno'd that Gamedog and another member did as well as others.
__________________
'08 BO/Graph -G37S Journey/Sport/Premium/Nav/Spoiler/Exhaust Depot Y-PIPE/ BBGK/ K&N/ Mich Pilot Sport AS+ 245F..275R/Tanabe NF210/ Stillen Cross Drilled/ Metal Matrix Pads Former Car '03.5 G35 Coupe Premium/ Sport/ MD Spacer Last edited by KAHBOOM; 05-29-2009 at 01:15 AM. |
#30 | |
Quote:
So, lets identify the variables. 1. variation per pull. Each pull will always vary, same car, pulls as close to each other as possible, no changes to the car itself. 2. Air Temp/Pressure 3. Air Humidity #1 can't be avoided. We all know that. 2. Temp/Pressure can be corrected for. Perfectly. pV = nRT. If IAT is higher, then output will be lower. Why? Because there is less actual air going into the engine. Cooler air = denser air, given the same pressure. Exactly why Intercoolers/Aftercoolers/Heat exchangers are used. They lower IAT, which allows for less boost (thus less pressure) to yield the same or more horsepower. A cool, clear day will always yield more power than a hot rainy day, which leads us to our third point. 3. Humidity can also be corrected for. 100% Humidity will yield less power than 0% humidity. Humidity is water in vapor form. Water vapor in the air displaces oxygen molecules (among others), so that less is available to combust, resulting in less output. Have I missed some variable that can lead to differing dynos? |
| Thread Tools | |
| Display Modes | |
