Go Back   MyG37 > Tech Area > Engine, Drivetrain & Forced-Induction
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 11-05-2009, 01:54 PM   #16
DmfG37sTT
STL's Finest
DmfG37sTT's Avatar
Trader Score: (0)
I would get it looked at very soon. If there is a problem, thinking it will go away will only cause more damage and possible the entire thing to be replaced. And my 2nd to 3rd and 4th and 5th I dont shift hard on. My gears are more like 1st to 2nd and 3rd to 4th. Just a straight down pull and my car seems to love those gears more than others.
__________________
2008 G37S Coupe, 6MT, 2% Tint
DmfG37sTT is offline   Reply With Quote
Old 11-07-2009, 11:22 PM   #17
Lightning_G37S
Trader Score: (0)
I had someone tell me it could've been a hotspot. Said just to let it sit for a couple days. Drove it a little bit and the vibration was gone. Do you still tink I should take it in?
Lightning_G37S is offline   Reply With Quote
Old 11-12-2009, 07:09 PM   #18
DmfG37sTT
STL's Finest
DmfG37sTT's Avatar
Trader Score: (0)
I have a local shop i use all the time that doesnt charge me for things like that when it comes to looking at it and seeing if everything is ok. If your able to get it checked easily I would still get it checked. But if a shop is gonna charge you out the a$$ then I wouldnt. If it drives normal and the vibration is gone you should be fine.
__________________
Old 11-12-2009, 07:13 PM   #19
oOmikeyboy
2008 Infiniti G37
oOmikeyboy's Avatar
Trader Score: (3)
Send a message via AIM to oOmikeyboy
The vibrations in the clutch would be the flywheel i think. According to the DIY clutch mod that was posted on here, if you remove the spring next to the clutch it will allow you to feel the vibrations in the clutch.
There is some vibrations, but that spring is supposed to eliminate it. Maybe yours is vibrating more than normal and the spring isn't suppressing all of it.
Either way, if it went away then it must have fixed itself?
__________________
2008 G37s 6MT Black Obsidian | 5% Tint | FI CF Exhaust | Berk HFC | Injen CAI | Up-Rev Tuned | Volk GT30 Mercury Silver | SPC Camber Kit | Toyo T1-R | KW-V3 | Ultinons 6000k HID | PIAA GT-X Fogs | and lots of love <3 ||
oOmikeyboy is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
