| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#1 |
5 Speed AT...
Heys guys...
Just wondering if anyone has had any problems shifting there AT while in sport mode... Thanks Erich |
| Sponsored Links | ||
#2 |
maybe your shifter,i had to have mine replaced at like 22k.although mine coul not go into ds mode.mine the only way you could shift manually was the paddles.
__________________
08 G37S Coupe Some Mods CF Spolier,20s FORGED Savini SV71 |
#3 |
___________
No problems with mine, and I use them on a daily basis. Might be something you want the dealer to check out.
#4 | |
MYG37.COM Sponsor
Quote:
#5 |
Shifting
Well when I put the car into drive it shifts fine....when I put into DS it sometimes does'nt change from D to DS... and when i go from drive to shift mode it will go into first but won't go to second...if you try to go to second a couple of times it will....hard to explain let me know if you need more explaination....thanks
#6 |
go to the dealer its the shifter is bad.trust me on this.my car had the exact same problem.
on the work order it says "customer states when shifing into ds mode won't go into d". misc interior-s0001 parts device assy-transmis-34901-jk60b. tell them a friend of yours had a similar problem.lol.
__________________
#7 |
thanks...always somthing...lol did you have all your mods done when you went?
#8 |
^of course i did.warranty was not an issue.hope the info helps.It took the dealer like a few days for them to even realize the problem.it would only be a act up once it reached full temp.so if they do a quick run when the car is cold,they would just call me and tell me "they can not duplicate".I had to tell them to let it get hot.once the shifterwas changed problem solved.MY 03 sedan never had SHIFTER PROBLEM.sold it with 82K.
__________________
| Thread Tools | |
| Display Modes | |
