| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#1 |
Post whores must die!!
Say hello to my UR Underdrive Crank Pulley
Just got my hands on those!
![]() ![]() ![]() ![]() Install Well it isn't the easiest job to do, unless you know what you're doing have it professionally installed. The OEM bolts are so damn tight it's not funny. The bolt which bolts the OEM Pulley to the crank shaft felt like it was welded to the crank! The mechanic suggested removing the starter and holding the flywheel from one side and unscrewing from the other and bingo the bolt is loose. A little WD40 and some pushing & hammering and it finally came out. Here's the bolt I'm talking about: ![]() OEM vs. UR side by side: ![]() ![]() The OEM felt so much heavier! Impression After driving around for a while it did feel like it revved faster when I floored it. It also felt a little more responsive when I was swimming through traffic. I wanted to get a before/after dyno on this but I was quoted like 300 bux!! That's more than the pulley & the install combined lol I'm happy with it, tails even easier to slide I'm not complaining haha
__________________
'08 AG G37S 5AT | Fully Loaded | Tint | Clear Bra | FI CF Catback | PC Rims | BB's V2 GK | Eibach Pro Kit | Painted Grille | 4x20mm H&R Spacers | Stillen 3rd Gen Intakes | FI Non-Res Test Pipes | Customized Fox Resonators | FR:245/40 RR:275/35 | UR Crank Pulley | PIAA Fogs Before you post: - Check out this lovely feature! - Read our Guidelines - Read the forum rules - Learn how to post Not knowing your way around? | Getting lost in this place? | Looking for factory manuals? | Want to become premier? | Want to mod but don't know where to start? | Need specs of OEM wheels? | Got G? Check In! | We know what a G looks like, what do you look like? | Classic post? Post it up Last edited by G37Sam; 05-11-2009 at 01:23 PM. |
| Sponsored Links | ||
#2 |
450whp or Bust!!
being that the UR pulley is just a bling factor.. you cant even see it under all the crap on top.. second of all ..your factory pulley is a dampener.. it has rubber insides which dampen the shock vibrations from your crank.. without that very bad effects can happen.. if the G uses a crank driven oil pump gear then kiss that goodbye. bottom line you will be super lucky if you can even get 1hp from this.
__________________
08 G37S PG - www.NoLimitMotorSport.com Last edited by G37Sam; 05-10-2009 at 11:02 PM. |
#3 |
factory pulley is not a dampener, I read it on the370Z that our engines are pre-balanced and pulley has no dampening effect
__________________
'08 AG G37S 5AT | Fully Loaded | Tint | Clear Bra | FI CF Catback | PC Rims | BB's V2 GK | Eibach Pro Kit | Painted Grille | 4x20mm H&R Spacers | Stillen 3rd Gen Intakes | FI Non-Res Test Pipes | Customized Fox Resonators | FR:245/40 RR:275/35 | UR Crank Pulley | PIAA Fogs Before you post: - Check out this lovely feature! - Read our Guidelines - Read the forum rules - Learn how to post Not knowing your way around? | Getting lost in this place? | Looking for factory manuals? | Want to become premier? | Want to mod but don't know where to start? | Need specs of OEM wheels? | Got G? Check In! | We know what a G looks like, what do you look like? | Classic post? Post it up |
#4 |
This is true...it also applies to the VQ35...but I found that gains were minimal if non-existant...it revs a little better...thats it.
__________________
08' G37-sport Package w/ Spoiler and Sunroof |
#5 |
Team Outcast
thats all sam need. he just like squeeling his wheels
__________________
TEAM OUTCAST |
#6 |
GOT CAMBER?
Hope you like it Sam!!
__________________
AUTOKITS-X CARBON FIBER REAR VALENCE & GRILLES l TANABE COILS l STILLEN SWAYS l MXP EXHAUST l BERK HFC l SSR'S l HANKOOK'S l INJEN CAI l TS BUMPER l 3K HID FOGS l ICHIBA CAMBER l KICS R40'S l ILLUMINATED SILLS l GROUNDING KIT l VLEDS l SPECIAL THANKS TO AUTOKITS-X l LOU@AMPLIFIED l AUTOGLITZ l |
#7 |
Please let us know when you install this, I'm really interested and might get it if it improves the throttle response and make the car rev faster!
__________________
Modular Concept 01 | Eibach Pro Kit | FI CF Exhaust & HFC | Stillen G3 | GT-Spec Strut Bar
SE CF Engine Cover | BB's CF V2 GK | AutoKits-X CF Rear Lip | MB Grille | JP Vizage Side Skirts ![]() |
#8 |
Installed, pix taken and a small review
__________________
#9 |
LA G's Club
Nice pics and review. Better engine response and revving, Im sold.
__________________
08 Vibrant Red G37S TeamLAGs.Com I see the hate in your eyez.
#10 |
Thanks for the review Sam. I appreciate you!
#11 |
450whp or Bust!!
if you want to achieve this then just get a lightened flywheel!
__________________
08 G37S PG - www.NoLimitMotorSport.com |
#12 |
sam idk about u but there was no improvement with this mod ..
atleast for me .. |
#13 |
well whoever said that the factory pulley is not a dampener is a complete moron....
i don't care how WELL balanced your engine is....it is never perfect...and with even the slightest vibrations, it can cause some serious damage without the factory harmonic dampener....(i know from experience)... even turning on your A/C can cause damage since the belt will vibrate when the A/C engages.... the vibrations may not cause any damage in the short run...but in the long run...you will start feeling weird vibrations coming from the engine..which you will feel in your cabin...followed by you kissing your crank seal good bye....once your crank seal goes...ur engine will pretty much drain all it's oil into your transmission (will slowly leak)... lots of people say that the harmonic dampener does nothing...i beg to differ...good luck for that extra 1whp, it's almost not worth a future full of headaches and empty wallets http://www.atiracing.com/products/da...mper_dinan.htm Last edited by gtracing; 05-12-2009 at 03:07 AM. |
#14 |
not on an AT though
__________________
#15 | |
Quote:
__________________
| Thread Tools | |
| Display Modes | |
