klonking noise on start up.
Old Dec 12, 2008 | 12:06 AM
FiremanJ's Avatar
FiremanJ
every time i drive for 30 min or more after i shut off the car and start it back up agian (not right away)... i hear a klonking noise almost like it's running out of gas and then the car starts up and drives normal. it only happens after i've parked it for a couple min then start it, but if i let it sit for like 10 min or during cold starts it doesn't have the problem.
it's been to the dealer twice, they said the easter oil would fix it but it didn't and brought it back on monday and got it back today and it made the same noise when i got back from work. i'm to the point where i'm going to drive it through the show room window.
Any idea's on what it could be, they said it was the VVEL and it was fixed but apperently it wasn't.
Old Dec 12, 2008 | 12:23 AM
Blackjack's Avatar
Blackjack
My initial thought was VVEL as well... Maybe they didn't fix it.
Old Dec 18, 2008 | 12:45 PM
anh3's Avatar
anh3
video files added
Hey, I had the same problem... and my engine is un-mod. It will ALWAYS happens if you shut the engine off and let it cool down, not cold but when the temp gauge is showing less than '1/4' warm.
here is a video: http://www.youtube.com/watch?v=Av5AY2snaBs
After a drive with the hot engine let it sit and cool down until the temp. gauge barely goes past the first tick mark, i.e. pointing at about 7 o'clock position(clockwise). That is when my engine made the noise everytime (and I suspect for other people also), too hot or cold start and it won't make the noise.
The noise is a very loud metallic 'crack'; almost sound like something an old engine would make or an engine that is out of timing, I have the sound attachment in zip files futher down from this post. The problem will be even more apparent if you live in cold weather (freezing tempt), it will happens soon enough like after shutting the engine off to fill up with gas and starting it again.
cuong.
normal=normal
noise=cracking noise at start-up
File Type: zip
File Type: zip
Old Dec 18, 2008 | 01:52 PM
Heat's Avatar
Heat
Fireman and ANH, When were your cars made?
Old Dec 18, 2008 | 02:09 PM
RIDEwithG's Avatar
RIDEwithG
I get this problem too. Usually after I drive it for 10-15 minutes, park and then I get the "clonk-clonk-clonk" sound, like the engine is on it's last legs. Of course I haven't had any performance issues. It still runs smoothly, it's more of an "annoyance" than anything else.
Old Dec 18, 2008 | 11:44 PM
FiremanJ's Avatar
FiremanJ
i believe the sticker on the door said 4-2008, but i'm not 100% sure and it's too cold and late to check
Old Dec 19, 2008 | 09:30 AM
Heat's Avatar
Heat
I wonder if it has something to do with that batch of cars. I figured since mine was made in the first batch of cars that I would have more problems but I havent. The only thing I had under repaired under warranty was that muffler weld that came lose. No biggie.
Old Dec 19, 2008 | 12:50 PM
ucla bruin's Avatar
ucla bruin
Can you guys get this on video?
__________________
Old Dec 19, 2008 | 01:52 PM
FiremanJ's Avatar
FiremanJ
i'll try but it wont happen untill next week when the snow melts... stock sport tires and snow = spin... thank god for the winter beater.
Old Dec 19, 2008 | 10:26 PM
shabbo's Avatar
shabbo
Is the RPM falling below normal idle speed when this happens?
Old Dec 20, 2008 | 02:20 PM
anh3's Avatar
anh3
update with video link: http://www.youtube.com/watch?v=Av5AY2snaBs
the noise happens the moment the warm engine is turn when you push the ignition and it goes away, you can't miss the noise even if the hood is close. it is definitely some kind of metal to metal contact noise, I am hoping for it to be the starter - as it ONLY happens right when the engine is starting up, but the noise sound very much like it to be a valve problem (timing). the noise was there before and even after I did the ITB with ECM reprog. and Ester oil change. Maybe I am too worry but my personal opinion is any metal to metal noise/deficiency is... not good, especially involving the engine or its peripheral parts.
again, if you want to investigate whether you have the noise do the following: after you drive your car (normal operating tempt), turn the engine off and let sit for about 10-15 minutes (depending on the outside temp, couple hours if above 60 degrees) or until the temp gauge is less than half way between normal operating temp and cold, the needle showing an almost cold engine. If you have that problem, you will definitely hears it.
I took mind to the dealership, and I turned my engine several times for them to confirm it, the noise comes up EVERY time I turn the engine.
Old Dec 20, 2008 | 04:53 PM
notalk's Avatar
notalk
Even when the engine is cold? FiremanJ says his only happens when the engine is warm.
FWIW, there have been a number of reports of the dealer having to reflash the software. Most dealers do not read the software version after flashing to verify they did the flash correctly. So, some have reported they have had to go back and have the flash done again. I suppose it is possible the flash did not take and your car needs to be reflashed. If the dealer, and I know it's an hour trip for you, reads your software version and you don't have the latest version, then they need to reflash your car.
Old Dec 21, 2008 | 01:06 PM
anh3's Avatar
anh3
No I never said when its cold, only when engine is warm, but also not when hot. I have had my ECM reprogrammed and ITB done on the ESter oil.
This is a new problem for them, they could not figure out why, they're contacting their tech-line for further instruction. In the meantime those of us who had the problem are driving a new car with a new problem and unknown solution...
Old Dec 21, 2008 | 03:24 PM
anh3's Avatar
anh3
sound clip of noise
alright, here they are, one is normal startup and the other one you can hear the distinctive crack, in zip files (mp3 when unzip). the noise can be heard masking the sound of exhaust growl when the engine starts. And I didn't start and shut the engine fast like that, I have to cut and edit to fit the 100kB requirement. But it will happen any time I start the engine within that temp range. When I brought it to the dealer last week, I turned the engine 5 or 6 times for the service manager and a tech to confirm it; the noise comes up every time.
File Type: zip
File Type: zip
Old Dec 21, 2008 | 06:32 PM
shumby's Avatar
shumby
keep us updated
