| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#1 | |
Quote:
If so, can you explain why? T.I.A. |
| Sponsored Links | ||
#2 | |
Quote:
Basically what I'm saying (look at the picture below) when you drive and high speeds this causes the tires to flare out which in turn causes uneven wear and will eventually cause your tires to begin to feather on the insides. You can do a good job of preventing this even if you drive around 90 on the highway if you get your car aligned often. Since our stock tires are very soft (180 treadwear) they will be more prone to feathering down the road.. I recommend (if you drive decent) having your car aligned around 6-8,000 miles and make sure you rotate your tires at a regular interval like an oil change. Hope that helps a little kind of difficult for me to explain so have a look on some tires sites.
__________________
2010 BMW ///3 Coupe - Alpine White G37S Journey Blue Slate/Graphite Premium, Sport, Nav, JL 12" W6V2 Car Domain |
#3 | |
Quote:
#4 |
Feathering is caused by the toe alingment. If your tires are alinged straight ahead, then you will have feathering when at high speeds. This is caused by the front tires toeing out of eachother. The only way to prevent this from happening is to aling. the front toe more in to eachother. Camber alingment does not cause feathering, just wear on either the outer edge or the inner.
#5 |
dang, im at 15K miles... hope they can still give it to me! ha, i prolly gonna need new tires by 20K anyway. =p
__________________
AthensBlue/Graphite | JWT PoPs | Lowered on EIBACHs | BGGK -- National G Club -- |
#6 |
President Of LA G's
Will my dealer still give me a free alignment even though I have the H&R springs?
__________________
08' IP G37 - President Of Los Angeles G's (LA G's) |
#7 |
Yup should, I know a few people who waited til they dropped their cars and had Infiniti do the alignment.
__________________
#8 |
After my dealer "aligned" my old G35 coupe the ride was never the same as factory again...
I for one don't plan to get my g37 aligned unless I'm sure it needs it.
__________________
2008 G37 Sport 6MT Amethyst Graphtie / Graphite, Premium, Navigation, splash guards |
#9 |
Saints Go Marching In!
Just went in for 15K service and needed and alignment so I'd advise all to go in before 12K and have it checked even if you don't notice anything. It would have saved me $160.
__________________
Get your custom grounding kits at |
#10 |
d@ r3^L3$t h0m3y i|\| 313
you're saying alignment made your ride worse? how, in what ways? did you have springs or coils in? That's so bizarre...
__________________
![]() 08 G37S 6MT OB/Graphite Prem/Nav/4WAS/Tech/Spoiler/23%Tint/Escort X50/JWT Pop-Charger/Mackin MXP Catback Exhaust/Motul 8100 X-Max 5w30 Synthetic Ester Oil Buy MOTUL oil for your VQ at MotorSpotStore, selling ester synthetic oils!
#11 |
Yeh that sucks I always get mine done around then regardless.
__________________
#12 | |
Quote:
Question: is the faster treadwear due solelyto the build of the Bridgestone Potenzas? In other words what I am asking is, does the G37 in terms of its weight, performance, center of gravity, suspension, etc. already leave tires vulnerable to faster wear or is that something associated with the tires themselves exclusively? The reason I ask this is because byt he time my Bridgestone Potenzas wear out I am hoping we will have better, longer lasting tires on the market to upgrade to.
__________________
#13 |
The Pontenzas have a very low treadwear of 180 which means the rubber is uber soft, good for a quite ride but not for longevity. Look for tires around 380-400 to maximize wear.
__________________
#14 |
yep an alseason pilot will give you the sportyness you are looking for and a longer tread life.
__________________
09 G37S 7AT/// FI HFC's/// FI Cat back/// Tint 35%7%/// 3M hood, bumper, mirrors,doordishes,headlights,rockers doorsills, a pillers,roof,rear wheel wells/// Clearplex windshield/// interior LEDs///Keyhole delete///R2C intakes///Strut Bar///BB Grounding Kit Wanted: SC |
#15 |
Potenza's are 180
Pilot Sports are around 230 if I remember correctly, that ain't much of a difference. 380-400 is better.
__________________
| Thread Tools | |
| Display Modes | |
