DIY: Pictures of JWT Oil Pan Spacer w Oil temp/pressure sensors installed
Old 08-29-2010, 07:37 PM
xlack
xlack's Avatar
This car belongs to weiboy718.
OEM Oil Pan removed:
1.
2.
3.
4.
OEM Oil Pan completely stripped of silicon residue:
5.
JWT Oil Pan Spacer:
6.
7.
New silicon applied:
8.
Brush used to remove silicon remains:
9.
10.
11.
12.
This bolt has to be bended in order for the oil pan spacer to fit. (guy from 370z forum had it cut off, but is not necessary):
13.
14.
15.
16.
17.
18.
19.
20.
Bolt is knocked back into position:
21.
22.
23.
24.
25.
26.
27.
Some pictures of the rides:
28.
29.
30.
Old 08-29-2010, 08:45 PM
Weiboy718
Weiboy718's Avatar
thanks for drawing on my car! you butt head!
Old 08-29-2010, 09:21 PM
Ivoidwarranties
Ivoidwarranties's Avatar
Awesome! How low does that put the pan? Are you still able to put the undercover on?
Looks like the pressure sensor install went fine. Well done.
You have a cooler and a spacer now right? How much oil does it take now?
Old 08-29-2010, 09:32 PM
Weiboy718
Weiboy718's Avatar
yes sir! the cover still mounts on perfectly. the spacer is an inch thick and it's not even touching the undercover at all. close though.
the GTM adapter was definately a life saver, without that i don't even know how i'm gonna hook up my oil pressure. all that work just to get the oil temperature reading ! at least now it all paid off well! my max oil temp only went to 202F on local driving and 180ish on freeway.
for everything i should have about 8qts in there.
Old 08-29-2010, 09:40 PM
Ivoidwarranties
What about the oil pressure? You do or don't have it hooked up? What kind of oil preesure are you seeing?
Old 08-29-2010, 09:50 PM
Weiboy718
Weiboy718's Avatar
yes, it's hooked up! the first one to the left is my oil pressure. the 25psi is at idle and 96psi is the past history.
Old 08-29-2010, 09:59 PM
Ivoidwarranties
Yeah, I seen that. I was just making sure. Does the pressure follow the rpm pretty well?
Old 08-29-2010, 10:13 PM
Weiboy718
Weiboy718's Avatar
ya, it's very responsive! at about 3-4k rpm i'm at 60ish psi. redlined it this morning it went up to 100psi.
Old 08-29-2010, 10:22 PM
TomieG
TomieG's Avatar
Wow very sick! So you all done with all of your supporting mods now?
Old 08-29-2010, 10:32 PM
Weiboy718
Weiboy718's Avatar
for now yes cuz i'm hella wacking broke! i'll get the HKS AFK later on. damn thing cost over 1k
Old 08-29-2010, 10:34 PM
TomieG
TomieG's Avatar
gotta pay to play bro! atleast you are doing it right and buying quality parts to do the job. you should have no problems down the road.
what does the HKS AFK modulate?
Old 08-29-2010, 10:44 PM
Weiboy718
Weiboy718's Avatar
A/F ratio and knock amp
Old 08-30-2010, 12:35 AM
Staples
Staples's Avatar
It's the "Top Secret" of widebands.
Old 08-30-2010, 08:26 AM
Ivoidwarranties
The Camp2 doesn't have any provisions for a wideband?
Old 08-30-2010, 09:29 AM
Weiboy718
Weiboy718's Avatar
Talking
Damn, keV! Don't u sleep lol?
The Camp2 does have the option for A/F only with FCON though.
Chris Olson
03-28-2024 09:46 AM
superjoey
31
03-22-2023 11:56 PM
warpeacelove
09-28-2015 10:39 PM
stevo4756
08-19-2015 10:14 AM
Quick Reply: DIY: Pictures of JWT Oil Pan Spacer w Oil temp/pressure sensors installed
