| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#1 |
need help, interior lights
I want to change the dome lights and the ones in the door but have no idea what I need to get. I went to pep boys and found "194 blue" bulbs, would these work? I have tried going on www.superbrightleds.com but dont know if i should order something from here (have no idea which ones) or should I just install these 194's.
let me know what you think, thanks. |
| Sponsored Links | ||
#2 |
Team Outcast
194 will work!
Superbrightleds and V-leds is perfectly fine!
__________________
TEAM OUTCAST
Street Works Automotive Amplified Motorsports ~ Endless ~ Driveline Motoring ~ Iconz Wheel ~ Detailed Image ~ AJAutoDetail |
#3 |
#4 |
Team Outcast
the LED last longer and looks better in color. The 194 works too but I find them tend to burn quicker.
It depends what color you are looking for. I use the 5k pure white in my car. which are these WLED-xHP High Power LED bulb ![]() if you want the white with a hint of blue 6k then i suggest these WLED-x6 LED bulb cool white 6k ![]() you will need a total of 6 pairs. 2 for dome, 2 for door, and 2 for license plate. You will need 1 single for trunk light.
__________________
TEAM OUTCAST
#5 | |
Quote:
#6 |
Team Outcast
you can get either the top one or bottom one in red or blue
. notice how the picture above has a red and a blue one
__________________
TEAM OUTCAST
#7 |
2009 Infiniti G37 |
check this out from HamstersG, I got the exact same setup as him and I LOVE it.
http://myg37.com/forums/body-interio...nse-plate.html (look at post #73 + 91)
__________________
09G37S//6MT//LOADED//20%//AUTOKITS-X//LIMITED EDITION//HP AUTO//AMPLIFIED MOTORSPORT |
#8 | |
Harmless Addiction
And the details at the link in my signature. As for blue, red, whatever, etc., suggest you just buy 1 or 2 and try them out in different places and figure out what you like best before order everything.
Quote:
#9 |
bro, nothing but LEDs for me, they are the sh*t, go here:
www.autolumination.com Tail Light Brake Light Turn Signal LED Bulbs |
#10 |
WLED-xHP5 Wedge Base Bulb Miniature Wedge Base Bulb(194/168 type) with 5 High Power SMD LEDs 12 VDC, 360 Viewing Angle, Polarized bulb Select LED color (I'm thinking of doing these in red, but would 5 LEDs be too hot for the dome lights?) ______________________ (are these the same as the above, just w/ 1 LED instead of 5?...If so what would be the difference in looks) _____________________ (since these are wide angles, would this be good for the doors? - if not, what would you suggest?) Thank you, Almost ready to place my order. |
| Thread Tools | |
| Display Modes | |
