Special Universal Air Suspension
Old Sep 2, 2010 | 11:54 AM
Fresh Ta Def's Avatar
Fresh Ta Def
Thumbs up Universal Air Suspension
Universal Air Suspension is one of the best Air Ride companies on the market to this date. It has built its rep on quality, safety, and dependability. It's one of the only Air Ride system on the market that lived up to it's name with keeping your performance needs and at the same time allowing the driver to raise or lower their vehicle anytime with no issues. It is made out of only high quality components with the best craftsmanship possible. The kit has proven itself to this community especially for your type of vehicle. It has establish respect upon it's reliability and durability to perform how an air ride system should at it's best. The Bag would go over almost any shock/coilover on the market by simply removing the current spring on the shock and replacing it with the bag, it will play it's role as a spring and do the job of raising/lowering your vehicle. This would even work with your OEM shocks and it would actually perform even better than OEM upon installation.
Here are some videos from U.A.S on the kit itself on their homepage.
Universal Air Spring & Suspension Company On-Road
(They have 2 videos on the home page)
Here is a vid of a RX-7 Drift Car running UAS Air Ride
http://www.universalairsuspension.co...?sid=53&cid=21
We recommend the Front/Back/Side to Side system for your Infiniti G35 & G37, this kit provided below is the best kit available from U.A.S for your vehicles, there are other set ups available by changing certain parts on the list to cut cost a little bit but this is the best recommended. This specific set up below also comes with a 3 year warranty.
F.B.S.S. SYSTEM INCLUDE
2 VIAIR 440C, 200 PSI, 100% DUTY CYCLE
1 200 PSI PRESSURE SWITCH
1 SWITCH BOX (Hand Held 9 Switch)
8 "Blow Proof" 1/2" AIR SOLENOID VALVE
2 UNIVERSAL AIR SUSPENSION AERO SPORT 9"
2 UNIVERSAL AIR SUSPENSION AIR HOUSE 8"
1 D.O.T. APPROVED FITTING & HOSES FOR F.B.S.S
1 CHROME ALUMINUM AIR TANK
1 SET OF BRACKET KIT
1 HEAVY DUTY SOLENOID
1 BOLT PACK
US PATENT US 6457702
MSRP: $2300
(Without Digital Gauges)
PM FOR FORUM DISCOUNTED BEST PRICING.
Old Sep 9, 2010 | 08:50 PM
Fresh Ta Def
One of the best Air Ride Kit on the market guys, the only that one that has been proven for Gs also. Your performance WILL be kept with coilovers and upon installing with OEM Suspension set up IT WILL be better than OEM. Alot of people have been worried about performance gains and I can promise you performance handling is improved upon installing it. Many people purchased coilovers and run it with UAS Air Ride and even track it with no issues, they're not settling for less with it, IT ACTUALLY WORKS. I have heard track stories where guys running UAS where out handling other vehicles with even expensive coilover set ups. Bump.
Check out this RX-7 Drift car running UAS Air Ride
Old Sep 20, 2010 | 07:33 PM
Fresh Ta Def
Bump! Go Air Now!
Old Oct 7, 2010 | 04:21 PM
Fresh Ta Def
Bump!!!
Old Oct 14, 2010 | 05:23 PM
Fresh Ta Def
Bump for best pricing and one of the most reliable proven kit on the market!
Old Oct 30, 2010 | 01:00 PM
Fresh Ta Def
Hit us up for Special Pricing guys. Go Air Now!
Old Nov 13, 2010 | 05:47 PM
Fresh Ta Def
Bump for Air!!!!
PM or Txt if any questions
714-679-3058 Chris
beng37s
Dec 8, 2019 01:21 PM
vamarris
Dec 9, 2018 11:10 AM
BurtoN86
Nov 3, 2015 04:40 PM
BurtoN86
Sep 30, 2015 03:32 AM
