Go Back   MyG37 > Tech Area > Brakes, Suspension, Wheels & Tires
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 10-26-2009, 01:51 PM   #1
ak1
Trader Score: (0)
replacing stock summer tires for the winter
Hi All,
I am planning to buy winter tires and rims for my 2009 g37s sedan to replace stock summer tires. I am going to buy tirerack recommeded package, Bridgestone Blizzak LM-25 , with 4 rims and 4 tires mounted and balanced.
I have several questions:
1. Should I buy option TPMS sensors for tirerack, it is extra 360$? What are pros and cons?
2. My undestanding that if buy TPMS from tirerack, I will need to go to the dealer to make my car recoginize new sensros and then repeat the same process with my old sensors in the spring. Is it correct?
3. If I do not buy sensors from tirerack, I have 2 options
a)move sensors to winter tires/rims from summer rims/tires and then repeat this process in the spring
b) Do not set up tpms at all on winter tires
What option would you suggest?
4. Once I get the tires/rims, is it easy enough to install them myself, or is it better to go to the shop? They are supposed to be mounted/balanced by tirerack.
I did seach these forums many times, still did not find enough info for me to make a decition. Please, let me know your thoughts/share your experience
Thank you in advance!
ak1 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-26-2009, 02:15 PM   #2
JKashat
"Mod Bug" & "Baby"
2009 Infiniti G37
JKashat's Avatar
Trader Score: (1)
Send a message via AIM to JKashat Send a message via MSN to JKashat
Get the LM-60's instead. They are replacing the LM-25's, unless you're getting a great deal. TPMS sensors can be reused from your OEM wheels unless you don't want them broken down, then get the ones from Tire Rack. Check w/ the dealer to see what they'll charge for OEM TPMS sensors, price seams high for aftermarket. Again, as you mentioned, you can just not use TPMS sensors at all and save some cash.
__________________
2009 7AT MW/Graphite | BB | Hotchkis | GT30 | Formula Lugs | Pirelli 255/30 & 305/25's | KWv3 | SPC Camber | MXP | Berk Test Pipes | R2C | GT Spec | CF Headlights/Grill/Splitter (IvoryGT) | IronMan V2.5 | PIAA 6600K | V-LEDs | Tints |
JKashat is offline   Reply With Quote
Old 10-27-2009, 07:05 PM   #3
Neal@tirerack
MYG37.COM Platinum Sponsor
Neal@tirerack's Avatar
Trader Score: (0)
I'd say the majority of people get the sensors with the package. They don't want to deal with the light/alarm that goes off when a sensor
isn't present. Helps out also when you see lots of temp fluctuations this time of year. The new sensors will need to be initialized at the dealer. Typically a 1/2 or so labor cost.
If you do move sensors from wheel to wheel you'll need a new sensor gasket kit each time they come apart and get transferred. Once the gaskets that hold the sensor together are un-torqued they shouldn't be used again. Those gasket kits typically run $3-4 per sensor. I would think that after mult mount/balance and trans sensors on two different sets of wheels they will pay for themselves quite quickly if just purchased. The cost, I think, would be worth the saved hassle alone.
Install of our packages is really not different than changing a tire on the side of the road. Only extra step is taking them to the dealer for sensor initialization (if you buy new sensors).
Feel free to call me or mention my name online when ordering
__________________
______________________
Neal, Sales Representative
1-877-522-8473 ext 624
Tirerack.com
Neal@tirerack is offline   Reply With Quote
Old 10-27-2009, 08:08 PM   #4
da mayor
Trader Score: (2)
Send a message via AIM to da mayor
i personally couldn't care if i drive w/o the Tire sensors in the winter... it's temporary... then in the spring you won't need to recalibrate the sensors in your OEM wheels.
__________________
[kennychan@infinitiofmassapequa.com][Turbo G sold]['07 FX45]['08 G37]['08 QX56]
da mayor is offline   Reply With Quote
Old 10-27-2009, 10:18 PM   #5
ak1
Trader Score: (0)
I called my local infiniti dealer this morning and they offered a reasonable deal on 4 blizzak LM-25 with new rims and 4 sensors, 1,500 for everything. They will replaces the tires and calibrate sensors for another 55$. So, I decided to go with this deal.
Thank you guys for responses and thank you Neal for the explanation how sensors are moved from the tires, I did not know that and it is good to know. I have read a lot of good reviews about tirerack.com, so the next set of tires for my car most likely will be from the tirerack
Old 10-30-2009, 10:25 AM   #6
Neal@tirerack
Trader Score: (0)
Sounds good give me a call!
__________________
Tirerack.com
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
