| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#1 |
2009 Infiniti G37 |
So I got my Eibachs installed and then got an alignment...here is my alignment sheet that shows all the before/after numbers. Do I need to get a front camber kit with the numbers as they are? Any opinions would be great!!
__________________
09G37S//6MT//LOADED//20%//AUTOKITS-X//LIMITED EDITION//HP AUTO//AMPLIFIED MOTORSPORT Last edited by hispeed-lowdrag; 01-18-2010 at 09:51 PM. |
| Sponsored Links | ||
#2 |
Nope not needed, seems like you're good to go Sir!
Your camber numbers are acceptable, toe was fixed pretty nice seems like the alignment shop knew what they were doing
__________________
'08 AG G37S 5AT | Fully Loaded | Tint | Clear Bra | FI CF Catback | PC Rims | BB's V2 GK | Eibach Pro Kit | Painted Grille | 4x20mm H&R Spacers | Stillen 3rd Gen Intakes | FI Non-Res Test Pipes | Customized Fox Resonators | FR:245/40 RR:275/35 | UR Crank Pulley | PIAA Fogs | Debadged & Valenced | Painted Headlights Before you post: - Check out this lovely feature! - Read our Guidelines - Read the forum rules - Learn how to post Getting lost in this place? | Want to become premier? | Want to mod but don't know where to start? | Need specs of OEM wheels? | Got G? Check In! | We know what a G looks like, what do you look like? | Classic post? Post it up |
#3 |
Did you let the car settle? Or was the installation and alignment back to back?
#4 |
2009 Infiniti G37 |
The springs got installed on a Friday and the allignment was the following Monday. Should I look at getting another allignment?
__________________
09G37S//6MT//LOADED//20%//AUTOKITS-X//LIMITED EDITION//HP AUTO//AMPLIFIED MOTORSPORT |
#5 |
2008 Infiniti G37 |
I disagree with Sam. I'd def get an alignment kit for the front. The camber is out -1.9 and -2.1...its gonna eat through your tires after a while. Rears are barely within spec. I dunno, maybe I'm anal but I like everything done correctly.
__________________
2008 IP G37S 6MT |
#6 |
I didn't say they were perfect but it seems like it's the most he could do without a camber kit which is somewhat acceptable
__________________
#7 | |
2008 Infiniti G37 |
Quote:
...However, that's not the case.
__________________
2008 IP G37S 6MT |
#8 |
Well the front camber is around -2 and the rears around -1.5
Toe for both fronts and rears are almost zero Curious to know what's considered acceptable in your books haha
__________________
#9 | |
2008 Infiniti G37 |
Quote:
__________________
2008 IP G37S 6MT |
#10 |
2009 Infiniti G37 |
is the caster something to worry about also? It's out a bit more than the camber, but I know the camber is something that can eat through tires, but I'm not really familiar with the adverse effects of out-of-spec caster. t
__________________
#11 |
Go Heat!
on Eibach PK its minimal wear in the front. I mean by the time most of the tire gets almost bald...you'll see a little more baldness in corner of tire.
Not worth an alignment kit IMO in the front. Now in the rear I would get one especially if you get 20 inch rims which are wider footing/wider offset. When I had my stock sport rims with stock tires and lowered on Eibach they wore uneven enough to eat up like 5,000 left miles on them.
__________________
X©alibūr» 2008 G37S - 6MT| Kicker | Stillen | Eibach | SPL | XIX | VOLK | Vredestein | SportWing | PIAA | V-LEDS | BERK | |
| Thread Tools | |
| Display Modes | |
