MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Go Back   MyG37 > Tech Area > Brakes, Suspension, Wheels & Tires
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 08-21-2009, 11:04 AM   #1
TicketProof
Trader Score: (0)
Alignment question, its been about 2 weeks since i had my Eibach springs
installed and it seems most on here recommend an alignment after the springs settle. However my alignment seems to be fine right now, the car tracks straight when driving and also during braking. Should i still take it in for an alignment even if it seems to drive fine ? does the camber get adjusted in some way or is a kit needed for that. thanks
__________________
[COLOR=Navy][B]08 G37[COLOR=Red]S[/COLOR] l PG l G l Nav l Prem l spoiler l illum. kickplates l Stillen Gen.3 CAI l MXP Catback l BBGK v2 l LED swap l Stillen sways l Eibach Pro-Kit | GT Spec SB l HPA 6000k HID's l Flat black grill[/B][/COLOR]
TicketProof is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-21-2009, 11:51 AM   #2
El mero mero!
2008 Infiniti G37
Trader Score: (21)
Yes. It may not pull but that doesn't mean it is in correct alignment. Have it checked. It it's correct (it shouldn't be) then you are fine. If not, it depends on how far off it is as to whether you need camber/toe kit. You may not. Post up your specs after you have it checked.
__________________
Get your custom grounding kits at
Black Betty is offline   Reply With Quote
Old 08-21-2009, 06:17 PM   #3
DJ Hellfire
DJ Hellfire's Avatar
Trader Score: (0)
Eibachs usually don't cause too much negative camber. You might be fine, but I'd still have them put the heads on and show you a print out. Like Betty said, adjust if needed.
__________________
2009 G37S Sedan RWD, Blue Slate, Nav, Premium, Auto
DJ Hellfire is offline   Reply With Quote
Old 08-21-2009, 06:24 PM   #4
TJHG37S
LA G Club
TJHG37S's Avatar
Trader Score: (12)
Send a message via AIM to TJHG37S
You should still get an alignment to get as close to factory spec as possible, whether it "seems" to be fine or not. Mine "seemed" fine after Eibachs but they were able to correct my camber and adjust toe and get it within spec which means less uneven tire wear.
DO IT.
__________________
08 G37S VR/Graphite - Team LA:G's | Los Angeles G's (Infiniti G37)
TJHG37S is offline   Reply With Quote
Old 08-21-2009, 08:46 PM   #5
G37Sam
2008 Infiniti G37
G37Sam's Avatar
Trader Score: (0)
Send a message via MSN to G37Sam
I really think you should get an alignment once settled in, here's why
G37Sam is offline   Reply With Quote
Old 08-22-2009, 12:00 AM   #6
Loi
Trader Score: (0)
Send a message via AIM to Loi
The worst part is the front camber wear, but it isn't even adjustable. The most an alignment can do is correct the toe and maybe a little camber in the rear.
__________________
2008 IP G37S 5AT - Volks SF-Challenge
Loi is offline   Reply With Quote
Old 08-22-2009, 04:59 AM   #7
FantastikG37
Trader Score: (3)
having a bit of negative camber won't hurt.. but incorrect toe will wear out the tires real fast.. so you should probably get an alignment just in case
FantastikG37 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
