AP Racing Teaser
AP Racing Teaser
Hey guy's! just came back from Stillen with some new brakes and a couple G's less in my pocket hahaha! i'll post more pic's later on.
Stillen and AP racing win win!Here's some specifications on Weiboy's brake kit..
Front Kit - AP5700
Calipers: AP Racing 6 Piston Caliper (CP7041)
• Lightweight, pressure cast aluminum alloy 2-piece body for better pedal feel than typical monoblock calipers
• Fixed radial mount for minimal caliper flex
• Hard anodized, then finished with a tough 2-part paint system
• Differential piston bores minimize pad taper and maximize braking efficiency
• Secondary dust seals for everyday use
• Anti-Rattle clip to eliminate pad knock
Rotors: AP Racing 14.25” x 1.25” (362mm x 32mm)
• Two-piece modular rotor floats on aluminum hat
• Directionally curved vanes for maximum cooling
• Cross-drilled and slotted for aggressive pad bite and better face cooling
• Slotted only rotors optional
Brake Pads: Mintex Xtreme Motorsport Compound
• Xtremely high friction for race pad stopping power
• Excellent grip -- From cold to over 1300°F (700°C)
• Linear & predictable under all conditions
Brackets:
• Aluminum caliper mounting brackets for maximum strength and stiffness
• Anodized for durability and appearance
Brake Lines and Hardware:
• Stainless steel outer braid with PTFE inner
Rear Kit - AP3750
Calipers: AP Racing 4 Piston Caliper (CP5147)
• Hard anodized then finished with a tough 2-part paint system
Rotors: STILLEN Brake Pros Two-Piece Rotors (330mm x 25.5mm)
• Two-piece rotor design
• Retains OE parking brake function
• Stainless steel outer braid with PTFE liner (DOT compliant)
• High performance hardware included
Brackets:
• Aluminum alloy mounting
6 Piston Fronts
4 Piston Rears
Update: after 2 days of driving it's finally starting to break in. The pedal feel is so much better stock. I don't even have to press the brake hard and it's better than the stock brakes. It looks good! Performs well!
Front Kit - AP5700
Brackets:
Rear Kit - AP3750
Brackets:
6 Piston Fronts
4 Piston Rears
