| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#1 |
Warped front rotors at 11K miles...
So I noticed that my steering would shimmy and shake when braking lately... I took it to the dealer for the 11K oil change and told them about it. I told them it was likely the rotors and they checked. It was.
Luckily for me, they said there was an issue with rotors warping on the G37 and they replaced the assembly under warranty. They did mention to me that if I brought it after 12K miles, they would likely not be under warranty. I'm just passing the word that if you have a rotor problem, take it in and have it replaced asap before they screw you. A car of this caliber should NOT have warped rotors within the first year of ownership. Anyone else with this issue?
__________________
08 G37S OB |
| Sponsored Links | ||
#2 |
Post whores must die!!
Everyone else had this issue, luckily you had them changed under warranty, there's a whole TSB about this.
PS Would appreciate it if you post in the right subforum next time
__________________
'08 AG G37S 5AT | Fully Loaded | Tint | Clear Bra | FI CF Catback | PC Rims | BB's V2 GK | Eibach Pro Kit | Painted Grille | 4x20mm H&R Spacers | Stillen 3rd Gen Intakes | FI Non-Res Test Pipes | Customized Fox Resonators | FR:245/40 RR:275/35 | UR Crank Pulley | PIAA Fogs Before you post: - Check out this lovely feature! - Read our Guidelines - Read the forum rules - Learn how to post Not knowing your way around? | Getting lost in this place? | Looking for factory manuals? | Want to become premier? | Want to mod but don't know where to start? | Need specs of OEM wheels? | Got G? Check In! | We know what a G looks like, what do you look like? | Classic post? Post it up |
#3 |
They still did it for me and I was at 17K miles.
Except something is still vibrating a little at hw speed. Not under breaking anymore so I dont know wtf is wrong.
__________________
|2008 PG G37S| |Premium|Navigation|20% Tint|LED's|Illuminated Kickplates|Valentine 1|Tanabe Medalion Touring|Ichiba Y-Pipe|5000K HID| |Injen SRI Black|BBGK v2.0|Yoko S Drives|GTspec FSB|Hotchkis Sways| New to the Forums? Learn to use this: Search Forums
#4 |
I am getting mine replaced at 25k.
Wakeboardr116 either your wheel balancing is off, or its the dredded "you have a small bend in your rim" are you rolling on stocks?
__________________
08 G37S Coupe,FI HFCs&Cat Back,Cobb W/Custom Tune,CF Spolier,20s FORGED Savini SV71 Last edited by RISKY GUY; 11-04-2009 at 01:42 PM. |
#5 | |
Quote:
Yeah stock wheels. I had the wheels refinished and new tires the first of August and have had to get them rebalanced 3 times. After the brake TSB it got better and eliminated it completly during breaking. So either I got a bad tire or its something else. I just haven't had the time to get it checked out with school and all.
__________________
#6 |
^ i think you have a slightly "bent rim" my 2 stock fronts are bad. the drivers side is worse than the passanger side. I had them redone a while ago.I refuse to keep spending $ 200 a pop to fix them.I bought some forged rims,but they are not even getting put on until the summer.
__________________
08 G37S Coupe,FI HFCs&Cat Back,Cobb W/Custom Tune,CF Spolier,20s FORGED Savini SV71 |
#7 |
When they were refinished though they had to redo the wheels to fix all the dings from the tireshop that screwed them up. So unless the place that redid them just didnt do it right. Here is my thread on the issue, i just updated it.
http://myg37.com/forums/brakes-suspe...ke-a-mofo.html
__________________
#8 |
My rotors went bad around 12k miles. Changed them under warranty at 15k. The company car I use once in a while is a Ford 500 with 70k miles on the original rotors.... just took it for brake pads change - the rotors in perfect condition.
Was Infiniti the high end Nissan or it was the other way around????
__________________
2008 G37S/ BLACK/ 6MT |
#9 |
2009 Infiniti G37 |
I had the same thing at 20,000 but i was really over my miles so i didnt take it to the dealer and ended up paying 900 for new rotors and brake pads..
#10 |
I'm at 13500 miles and my rotors are still good...I wonder how many miles the TSB is good for.
__________________
08' G37-sport Package w/ Spoiler and Sunroof |
#11 |
I'm at 25000 and I'm getting this under warranty
__________________
Fast Int CF-Injen-Tein-SPC-8k-3K HID Fogs-Vossen VVS 083's-CF Diffuser!!! |
#12 |
Is the shaking u guys experience only when braking or is it also when cruising at high speeds?? My steering wheel shakes a little when I get up to about 75-80MPH, but I assumed this is because I haven't had my car alligned yet since I had my S-Techs installed.
__________________
08 G37S BO, 6MT, 18% tint, magnaflow catback exhaust, JWT Pop Chargers, Vossen 085's |
| Thread Tools | |
| Display Modes | |
