MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Go Back   MyG37 > Tech Area > Brakes, Suspension, Wheels & Tires > Brakes & Suspension
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 09-01-2009, 02:07 PM   #1
LightningG37
Trader Score: (0)
Would a camber/toe kit tilt my tires out and rub worse??? Would machining help?
I don't still have the spec on my 20" Volks but the offset is very aggressive. Even with the fender bracket and skirt trimmed it rubs during moderate to aggressive driving or with passengers. I was planning on having the wheels rear face machined cause the tire wear was horrible and I blew out after 11K.
So here is my main question, if I get a camber kit installed and have the camber adjusted to spec, would that tilt the top of the wheels out and make it rub worse? I'm trying to decide if I can fix this with machining or if I need to buy new rims. Currently lowered on Eibachs. Thx.
__________________
08 VR/Wht G37; 20" Volk GTCs, Eibach Pro-Kit; Grubbs v2 Splr; Mobile Theater; Bats.
LightningG37 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-01-2009, 02:29 PM   #2
HamstersG
Harmless Addiction
2008 Infiniti G37
HamstersG's Avatar
Trader Score: (3)
Without offsets and sizes it will be hard to give a detailed answer, but in general the answer to your question is yes. If dial in less negative camber = top of wheel/tire will come toward edge of fender = more rub.
__________________
G37S
<--- Mod Details in 2008 Infiniti G37
______________________________
HamstersG is offline   Reply With Quote
Old 09-01-2009, 02:30 PM   #3
Triple_X
2009 Infiniti G37
Trader Score: (3)
I got the SPL camber arms for dirt cheap if interested
__________________
09 BS G37xCoupe
Triple_X is offline   Reply With Quote
Old 09-01-2009, 02:31 PM   #4
HamstersG
Harmless Addiction
2008 Infiniti G37
HamstersG's Avatar
Trader Score: (3)
And are you sure you trimmed enough of the fender bracket and lining like shown in Blackjack's posted thread?
__________________
G37S
Old 09-01-2009, 02:54 PM   #5
LightningG37
Trader Score: (0)
Sharif at Forged did the work and I think it was pre-Blackjacks thread but that being said, yeah, they trimmed off a great deal and over the last year, the tire has done the rest to the point that the bolt is barely hanging on. That's one of the big reasons I need to get the wheels machine, cause if I rub any more I think the last of the bolt mount will go and the bumper will sag on the sides.
I think these specs are correct:
22 in the rear 26 in the front (offset).
The tires are Toyo T1R 245/35/20f, Toyo T1R 275/30/20r.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
