| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to myG37 forums! |
Welcome to myG37 Forums. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today! |
Thread Tools | Display Modes |
#1 |
Illuminated Door Sills
Installed them yesterday, took about 2hrs but I was taking my time. Install is pretty easy other than a few things:
Instructions are vague; you need to take some time to sort out what they are saying in the areas of connecting the electrical blocks and putting masking tape extensions on the 2-side tape so you can pull the protective layer off while it’s almost in place. I’m a little concerned how well the 2-side tape will hold up long term. The new sill’s only use that adhere to the car where the stock sills use clips. It’s a subtle Mod but I think they add a touch of class. Removing the two plastic vent covers that are on either side of the center console area up under the dash was a pain. One clip broke even though I took care. They are the tab/slot kind. Putting them back on they didn’t latch very well (even the one I didn’t break) so I’ll wait and see if they stay.
__________________
2008 Journey,Premium,Blue Slate | Illuminated Sills | LED's-Trunk,Door,Map & License |
| Sponsored Links | ||
#2 |
If you cleaned the area before you stuck them on.....trust me...they will not be coming off haha. That is some serious adhesive and if applied correctly they will not come off.
__________________
08 G35S 5AT Oreo Sedan - GTM RTP - H-pipe - Magnaflow- Gen2 Stillen - BB grounding wires |
#3 |
Cleaned it with soap and water then with 50/50 water & rubbing alcohol as instructed. Guess they are on there then :-)
__________________
#4 |
They are there for the long haul....you would have to pry them to get them off and probably still wind up putting a dent in the aluminum before they came off haha. Ive used similar adhesives like that before and learned that if you dont it right the first time, you're screwed lol
__________________
| Thread Tools | |
| Display Modes | |
