Notices
Shift Knob : Help with Removing
Old 10-17-2007, 06:51 PM
Volk350z
Volk350z's Avatar
Shift **** : Help with Removing
Anyone took off their OEM shift ****?? if you did how did you do it?
Old 10-19-2007, 06:08 PM
UNV-IT46
UNV-IT46's Avatar
if its like most oem ***** there should be a locking nut right under the bottom of the **** which once you remove the **** should just unscrew.
Old 10-19-2007, 10:13 PM
RedHerring
RedHerring's Avatar
You may need a rubber strap wrench to grab the **** tightly enough to turn it without destroying it. They put blue loctite on it usually. Also do not put any torque on the shaft. (That doesn't sound right.)
Old 10-20-2007, 09:34 AM
ivory37
ivory37's Avatar
what **** you getting ? I kinda like the OEM one
Old 10-25-2007, 12:44 PM
Volk350z
Volk350z's Avatar
putting on the ARC Titanium ****..
Old 10-27-2007, 07:06 PM
SLaPiNFuNK
SLaPiNFuNK's Avatar
Its actually the same exact shifter as what is on the V35...
Lift up the shift boot console (not the leather boot, but the whole plastic surrounding)
Put a set of vice grips on the shifter shaft
Put a towel over your stock shift **** and put a pair of pliers onto it
hold the shifter shaft in place with the vice grips and turn the pliers..
Old 11-05-2007, 09:27 PM
UNV-IT46
UNV-IT46's Avatar
the upper boot cover can not be removed as there is a bolt holding it down into place...
Old 11-06-2007, 01:53 AM
SLaPiNFuNK
SLaPiNFuNK's Avatar
Ill look at my fast system / service manual when I get to the office tomorrow...
I figured the center console dash would lift up the same...
either way, once that console is lifted up, then follow the steps..
Old 11-06-2007, 03:32 PM
SLaPiNFuNK
SLaPiNFuNK's Avatar
What bolt are you talking about?
You do not remove the Leather Boot from the plastic console... You put your hand inside the leather boot and pull up on the plastic console...
Old 11-06-2007, 03:35 PM
UNV-IT46
UNV-IT46's Avatar
there is a screw on the end of the boot i.e. cloest part to you if you were sitting in the car. It holds the whole plastic shift ring that the leather boot is attached too. You can get the whole ring up like you said by pulling but on one part it wont come up because there is a screw holding it down....
Old 11-06-2007, 03:37 PM
SLaPiNFuNK
SLaPiNFuNK's Avatar
oh... you dont want to pull up the ring.. you want to pull up the complete console...
Ill go do it on a car rite now...
hehe
Old 11-06-2007, 03:41 PM
SLaPiNFuNK
SLaPiNFuNK's Avatar
ok its from a different spot.. but some concept...
in this picture below, I am holding one side... you want to hold BOTH sides... one with your left hand and then the oposite side with your right...
so do not pull up on just one side... but both sides...
pops up pretty easly...
Old 11-06-2007, 03:50 PM
UNV-IT46
UNV-IT46's Avatar
ya i got that far no issues but it was still really tight because its attached to that black plastic piece under with a single screw I pried a little more and the whole lower metal concole came up which worked best....
Old 11-06-2007, 03:54 PM
SLaPiNFuNK
SLaPiNFuNK's Avatar
Just need to get it high enough to grab the shifter shaft with some vice grips and then go to town on the shift ****...
Put a towel over it and then take some plyers to it holding the vice grips in place...
Old 11-06-2007, 03:55 PM
UNV-IT46
UNV-IT46's Avatar
sounds good to me, my arc **** should be here tomorrow or thur so i need to get that on.
Quick Reply: Shift Knob : Help with Removing
