MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Go Back   MyG37 > Tech Area > Audio, Video & Electronics
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 10-14-2009, 03:26 PM   #1
DJ Hellfire
DJ Hellfire's Avatar
Trader Score: (0)
Question UPDATED: Need HELP transferring iPhone contacts via Bluetooth using laptop!
So I think I am on to something here. Since the iPhone can't beam files over bluetooth (i've even tried jailbreak apps, none worked), I figured it can be done via laptop. It's my assumption that you can swap bluetooth devices on the G's system and still maintain the contacts, correct? So if this works, we will be able to send our contacts with the laptop and then switch the device to the iphone and keep the contacts from the laptop. I am close, but I am stuck.
I have managed to pair the laptop with the G. To do this, I bought a USB bluetooth interface since I did not get built-in BT with my laptop. I then went into the G's system and went to pair new device. Then on the laptop, I went to add device. I entered the G's 1234 passkey into the laptop and the two pair instantly. My laptop shows up on my G's system as the name of my laptop. It shows a slash through the phone icon (since the laptop has no phone), and also displays the battery of the laptop.
Now here is where I am stuck; and this part may be easy for one of you to figure out. I do not know how to make a .vcf phonebook file that contains all my contacts. I am on Vista using Windows Contacts and when I beam the contacts from the laptop to the G, the G is only downloading the first name in the contacts list. I assume that this is because all the contacts are their own .vcf file, instead of an entire phonebook .vcf file that contains all the contacts in one file.
So, how exactly do I go about creating this phonebook file?
UPDATE:
So I figured out how to get the contacts from the laptop to the car. Using Windows Contacts on Vista, I exported all the contacts to .vcf files in one shot. But here's the fun part. To get all the contacts in one file, I had to create a Notepad file and name it G37S.vcf. Next, right-click my first .vcf contact that I just exported and select "Open With" and choose notepad. Then the contact info opens up in a new notepad window. I copied all that info into my G37S.vcf Notepad document and saved. Then I had to do the same thing with the rest of my 113 contacts. In the end, the G37S.vcf document had a nice long list of contact info in vcf format. I then took the laptop back out to the car, paired it with the car, went back to download all and it took every contact in less than 2 seconds.
Now here is where I am stuck again. I can't figure out how to swap the pairing of my laptop with my iphone without the car deleting all the contacts. I think I recall someone figuring this out a while back. So if anyone has a clue how to do this, please chime in. Thanks! Almost there, hopefully!
__________________
2009 G37S Sedan RWD, Blue Slate, Nav, Premium, Auto
DJ Hellfire is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-14-2009, 06:30 PM   #2
hispeed-lowdrag
2009 Infiniti G37
Trader Score: (2)
Send a message via AIM to hispeed-lowdrag
I dont know if it exactly what you need, but if you go to iTunes and backup your iPhone I know that creates a file with all your contacts and such. Maybe you can use that to get the contacts onto the G's system?
Props for trying the laptop with the G, I never would have even thought about that. Hopefully you figure out a way for all of us with iPhones to get our contacts onto the G!!
__________________
09G37S//6MT//LOADED//20%//AUTOKITS-X//LIMITED EDITION//HP AUTO//AMPLIFIED MOTORSPORT
hispeed-lowdrag is offline   Reply With Quote
Old 10-14-2009, 07:46 PM   #3
BocaIvan
2009 Infiniti G37
Trader Score: (0)
Send a message via Yahoo to BocaIvan
This might work, keep us posted.
BocaIvan is offline   Reply With Quote
Old 10-14-2009, 08:22 PM   #4
DJ Hellfire
Trader Score: (0)
Quote:
iTunes uses Windows Contacts on my laptop, which is what I am trying to use.
__________________
Old 10-15-2009, 01:10 PM   #5
DJ Hellfire
Trader Score: (0)
Update in first post!
__________________
Old 10-15-2009, 02:20 PM   #6
BocaIvan
2009 Infiniti G37
Trader Score: (0)
When you created the G37S.vcf did you copy all the data from each of the individual .vcf files?
Old 10-15-2009, 03:51 PM   #7
marsb007
Trader Score: (0)
As far as I know the car keeps separate phonebooks for each one of the devices paired.
Maybe changing your bluetooth address (MAC address) to the same one used by your iPhone would work, but I haven't tried it, and don't even know if it's possible...
Good luck, and let us know... I'm sure everyone would want to figure it out...
__________________
2008 G37 Journey | Platinum Graphite | Graphite | Premium | Nav | Sports | Tech | Spoiler | 15% Tints
marsb007 is offline   Reply With Quote
Old 10-15-2009, 11:30 PM   #8
DJ Hellfire
Trader Score: (0)
Quote:
Yup! Took about 10 minutes. But I had to do 114 contacts. Some people don't have that many, so it would be much quicker for some!
This is what the contacts should look like in your G37S.vcf. This is only 3 contacts. I have 114 of these:
BEGIN:VCARD
VERSION:2.1
N:;411
FN:411
NICKNAME:411
TEL;HOME;VOICE:8003733411
REV:20071030T172106Z
END:VCARD
BEGIN:VCARD
VERSION:2.1
N:411;Google
FN:Google 411
NICKNAME:Google 411
TEL;HOME;VOICE:8004664411
REV:20071030T172446Z
END:VCARD
BEGIN:VCARD
VERSION:2.1
N:;Voicemail
FN:Voicemail
NICKNAME:Voicemail
TEL;CELL;VOICE:*86
REV:20071030T172714Z
END:VCARD
__________________
Old 10-16-2009, 07:35 AM   #9
BocaIvan
2009 Infiniti G37
Trader Score: (0)
Thanks! I have my vcf file ready to go, just need to get that blue tooth adapter you mentioned and waiting for someone to post how to pair the iPhone back!
Old 10-17-2009, 05:50 PM   #10
DJ Hellfire
Trader Score: (0)
Rocketfish™ - Micro Bluetooth USB Adapter - RF-MRBTAD
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
