MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Go Back   MyG37 > Tech Area > Audio, Video & Electronics
Welcome to myG37 forums!
Welcome to myG37 Forums.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join myG37 Forums today!
Thread Tools Display Modes
Old 10-09-2008, 11:34 AM   #1
ironchef2008
2008 Infiniti G37 Coupe
Trader Score: (3)
Bose Audio Wiring Breakdown
Here's a wiring breakdown for the Bose amp and Woofer amp. Please note that wiring color may not be the same at the speakers. These are for at the amp only and the pin number reflects the harness seen from where the wires go in, not the terminal side.
Bose Amp
Harness B42 (Pin Number/Item/Color Code)
(1) Front Left Mid/Tweeter + (L)(Blue)
(2) Front Left Mid/Tweeter - (W)(White)
(3) Front Right Mid/Tweeter - (LG)(Light Green)
(4) Front Right Mid/Tweeter + (V)(Violet)
(5) Front Right Woofer + (G)(Green)
(6) Front Right Woofer - (R)(Red)
(9) Front Left Woofer - (W)(White)
(14) Front Left Woofer + (B)(Black)
(10) Power/Key (Y)(Yellow)
(11) Power/Constant (GR)(Grey)
(12) Ground (B)(Black)
Harness B41 (Pin Number/Item/Color Code)
(16) Rear Woofer + (SB)(Sky Blue) **Signal to woofer amp
(17) Rear Woofer - (V)(Violet) **Signal to woofer amp
(18) Rear Left Mid + (L)(Blue)
(19) Rear Left Mid - (P)(Pink)
(23) Rear Left - (SB)(Sky Blue) **Preamp from HU
(24) Rear Left + (V)(Violet) **Preamp from HU
(25) Rear Right - (Y)(Yellow) **Preamp from HU
(26) Rear Right + (BR)(Brown) **Preamp from HU
(29) Center + (L)(Blue)
(30) Center - (O)(Orange)
(31) Rear Right Mid + (LG)(Light Green)
(32) Rear Right Mid - (Y)(Yellow)
(33) Front Right + (R)(Red) **Preamp from HU
(34) Front Right - (G)(Green) **Preamp from HU
(35) Front Left + (P)(Pink) **Preamp from HU
(36) Front Left - (L)(Blue) **Preamp from HU
(20) Power/Amp On (W)(White)
Woofer Amp
Harness B43 (Pin Number/Item/Color Code)
(1) Rear Right Woofer + (G)(Green)
(2) Rear Right Woofer - (R)(Red)
(4) Rear Left Woofer - (B)(Black)
(5) Rear Left Woofer + (W)(White)
(8) Rear Woofer + (SB)(Sky Blue) **Signal from Bose amp
(9) Rear Woofer - (V)(Violet) **Signal from Bose amp
(3) Power/Amp On (GR)(Grey)
(7) Power (Y)(Yellow)
(10) Ground (B)(Black)
__________________
Infiniti 2009 M35X
Last edited by ironchef2008; 10-09-2008 at 06:21 PM. Reason: Updated wire colors to reflect actual and codes
ironchef2008 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-09-2008, 12:09 PM   #2
Blackjack
2009 Infiniti G37
Blackjack's Avatar
Trader Score: (3)
Send a message via AIM to Blackjack
Good stuff... Thanks for posting.
__________________
09 G37S Coupe 6MT -- Moonlight White | Graphite | Premium | Nav | Tech | 4WAS | ClearBra | 35% FormulaOne Tint | KW Variant 3 | SPL Pro Rear Camber Kit | Vossen VF051 Custom |
RIP -- 08 G37S Coupe 5AT 11.2007 - 02.2009
Maintained with products exclusively from Detailed Image
Blackjack is offline   Reply With Quote
Old 10-09-2008, 01:39 PM   #3
arbelaezr
Trader Score: (0)
cool but what colors are the color code? P can be pink or purple.. Can u post the colors?
arbelaezr is offline   Reply With Quote
Old 10-09-2008, 06:09 PM   #4
ironchef2008
Trader Score: (3)
B = Black
W = White
R = Red
G = Green
L = Blue
Y = Yellow
LG = Light Green
BR = Brown
OR or O = Orange
P = Pink
PU or V (Violet) = Purple
GY or GR = Gray
SB = Sky Blue
CH = Dark Brown
DG = Dark Green
• When the wire color is striped, the base color is given first, followed by the stripe color as shown below:
Example: L/W = Blue with White Stripe
__________________
Infiniti 2009 M35X
Old 10-10-2008, 09:17 AM   #5
arbelaezr
Trader Score: (0)
Ok thanks .. I just realized u already had Them written out the 1st time .. My bad..
Old 10-10-2008, 06:55 PM   #6
Igor911
Trader Score: (0)
Send a message via AIM to Igor911
So when installing just a subwoofer / amp, are these the wires that I can tap to power my amp inputs?
Or will I need a special filter to tap into first, before powering my amp?
__________________
G37S 6MT PG/G - Prem | Nav | Tech | Spoiler | Splash | HID | Stillen Gen 3 | Nav Hack
Igor911 is offline   Reply With Quote
Old 10-10-2008, 08:01 PM   #7
ironchef2008
Trader Score: (3)
Yes and no special filter needed as they are low voltage signals.
__________________
Infiniti 2009 M35X
Old 10-11-2008, 02:21 AM   #8
Igor911
Trader Score: (0)
Quote:
what about tapping into :
__________________
Old 10-11-2008, 08:10 AM   #9
ironchef2008
Trader Score: (3)
Others have done so here on the forum with no problems. I would say it depends on your amplifier. If it accepts both high and low inputs, then you're fine no matter.
__________________
Infiniti 2009 M35X
Old 04-05-2009, 10:07 PM   #10
ProstylezG37
Trader Score: (0)
aaanyone know what size each speaker is?
__________________
[08 IP 6MT] [H&R] [Front Splitter] [Greddy Ti-C+ Ichiba Y-Pipe] [Eibach Camber Kit]
ProstylezG37 is offline   Reply With Quote
Old 04-06-2009, 06:46 AM   #11
ironchef2008
Trader Score: (3)
Geez man, at least try to search! There's many, many posts refarding speaker sizing.
Dash: 3" Mid
Door: 1" Tweeter, 3" Mid, 10" Woofer
Rear Side: 3" Mid
Rear Deck: 6x9" Woofer
__________________
Infiniti 2009 M35X
Old 11-23-2009, 05:41 PM   #12
groovinater23
Trader Score: (0)
I read that there's a bit of a difference for the Sedan...obviously a different speaker setup. Does anyone have the details or a diagram for this? I'm about to do a system in mine. If not I'll see what I can diagram as I do it.
groovinater23 is offline   Reply With Quote
Old 11-24-2009, 02:10 PM   #13
groovinater23
Trader Score: (0)
I found the 08 g35 sedan wiring diagram from the service manual via InfinitiHelp.com and it looks as if it's the same as the 37's. Maybe everyone already knew that. The only real differences is that it looks like the rear door speakers in the sedan run off the same wires as the rear mids do in the coupe, so 18, 19, 31,& 32. Also since there's 1 sub, there's a B46 connector with fewer pins than the B43. The main thing to know is that the sub signal is on 1 (V-) and 2 (SB+) instead of 8 & 9. I haven't dug into the car yet so if they changed anything from 08 to 09, this could be wrong, but I doubt it. The sub amplified signal to the speaker comes from elsewhere, but that is obvious since you just follow the leads to the sub itself. Hope this helps some Sedan guys!
Old 12-10-2009, 07:19 PM   #14
JKashat
2009 Infiniti G37
JKashat's Avatar
Trader Score: (5)
Send a message via AIM to JKashat Send a message via MSN to JKashat
How much depth does the coupe have where the 10" woofer goes?
__________________
2009 Moonlight White G37S Coupe
Getting rid of the G.
Let the part out begin...
JKashat is offline   Reply With Quote
Old 01-20-2010, 01:47 PM   #15
jbrady3324
Trader Score: (0)
So it looks like I can just toss in my amp/sub in the back and use the current wires going to the Woofer and/or Bose Amp. If I replace the 3ways in the front, can I still leverage the Bose Amp? When I do replace the Bose amp, will I need to re-wire the entire car?
jbrady3324 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise on MYG37 - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
Copyright ©2002 - 2009, MYG37.COM All Rights Reserved.
Zipcode new used
